green93
Pardon my newbyness, but I have a problem that I have searched high and low for and have not come across any solutions to.
I can be driving down the highway around 65mph and the dash starts to click and flicker. The SES light starts clicking, or there is a clicking noise associated to the timing of the SES light going on and off. The entire digital dashboard goes nut. RPM guage shows between 0 and 5000 RPM erattically. The speedometer shows 4, 5, 6, 7. It just jumps around and goes crazy. It also backfires and runs like it is a 3 cylinder vehicle, :confused .
If I pull over and shut it off or let it die which it will do sometimes and start it again it starts fine and runs then after about 1 minute of getting back on the road it starts the routine all over again. Last time it happened I started it and it was doing this on startup, I turned the ignition off and pulled the key. Put the key back in and started it up until it would start and run as designed. Took around 15 minutes to get back to normal. As soon as I took off again it let me get about 1.5 miles and started again. Pulled over and performed the same process again. This time when I started driving the car ran like it was supposed to all the way home.
First off my optispark has decided to die after owning the vette for 7 weeks, which 4 of those weeks was at a repair shop attempting to diagnose the problem that turns out to be the optispark. After 1350.00 for a fuel pump replacement and still having the problem I decided to find out on my own. Got a code reader and seen that I was getting a 16 and 42. Found lots of posts on the opti. I am having the opti, water pump and a new delteq coil pack installed this weekend. But I am not sure this will relieve me of the problem described above.
Has anyone seen the flickering SES light before?
Randell (Green93)
1993 Corvette LT1
350ci 6sp DR450hp
Randell (Green93)
1993 Corvette LT1
350ci 6sp DR450hp
