Raggs
Hey guys, my 93 smokes on cold start after sitting for a week. It is fuel smoke. I replaced the fpr, no help, every injector ohm'd at 11.8 ice cold. Any ideas?? Thanks!
OK, did the leak down test. Started at 4:44 with 41psi. then, 4:47 39psi, 4:51 34psi, 4:57 28psi, 5:03 18psi, 5:07 10psi. So I am going to assume that the injectors are the problem. I know the check ball in the pump could also be bad but I'm thinking injectors.:confused
If your '93 has Multec injectors (my '92 did), the 10% ethanol in today's fuel may break down the enamel wire inside the injector. I do not know if this will lead to a "leaky" injector, but in time those Multec injectors may develop problems. I replaced mine with Bosch Design lll's while diagnosing another problem.
Has anyone heard of the ethanol in today's fuel being incompatible with fuel injectors that are 15 or more years old? Is there truth in this or is it another urban legend?
CG
CG
Yes. I am doing PROM tuning, so I already took that into account. Thx.You know that Bosch III's are 24lb inj. and 92-93's call for 22lb.
