You a relative of Smokey Yunick or something?
No,Ralph M. Jones(Farmer),Charles W. Anderson Sr. (Machinist,Fabricator)and Charles W. Anderson Jr (Machinist,Fabricator,Radiator Repairman and Electrician)!!
First two being my Grand Daddy's,and 3rd being My Daddy,always stressed to my brothers and I was,"Everything has a Sweet Spot" (Where everything just Sounds, Feels Right and Runs with the most Efficiency!)!!Don't matter if it's a Farm Implement,Car,Truck,Motorcycle or Woman, Every one is a little different,but Find it and you'll have a Less Stressful,Low Maintenance Life!! "If it's got Teat's or Tires,There's always going to be Problems and Expense,But there ain't no need in causing more of it for yourself"!!
When we were young (7-17) I can't even beguine to remember how many times my Grand Dad Jones came to the field and got on us boys for not driving his tractors the way he liked,He could tell by the sound of each of his tractors from 3/4 mile away if any one of us or all of us hadn't found the SWEET Spot!! Didn't matter if we were plowing,disking or cutting and bailing hay!!
Now you being a Master Technician should kinda understand just what I'm saying!!
In all honesty thats the best I've ever done on a long trip,(usually around 32-34) and yes I check every once in a while with a calculator on the road between fill ups!!(Never found the DIC off more a tenth or two one way or another between fill ups or 4-6 tenths over the whole trip!!)
Now about how I do it with 87 octane,It's purdy simple,I've found the "Sweet Spot" and I run with it!!
I don't wring it out through the gears allot,I use 1st-3rd-5th allot and don't run it through all the gears,I set the cruse on the open road between 79-82 MPH in 6th depending ("Sweet Spot") on where I'm at and traffic!!And I won't put gas with Alcohol in it if I can keep from it! I use Chevron or Texaco 1st,Shell or Exxon/Mobil 2nd, BP or Phillips 66 3rd!! (I've got a case of the Azz at Phillips 66 right now,I got some alcohol in Missouri from a pump that wasn't Labeled!!)
It Run like Crap and the gas gage quit in less than a 100 miles!! I had to Tectron the heck out of it!! If I pull in and the pump says it has Alcohol.I either go across the street or put a little 89 in it depending on how low I ran it!!
Most people won't give the the ECM a sporting chance to get things right with the change in Octane!!:W:WThey'll be goosing on it here and there to see if the ping is still there or if the acceleration is off or just whatever!!
It just makes things just take longer,the ECM will make more changes than just the timing over a little time!!
My better half can get in anything and knock my average down from 15 to 25 % in 100 miles or less and says that her driving habits has not a thing to do with it!!
She always complains on how much gas her 4.3 Jimmy uses,"oh it only gets 16-17.5 MPG!! Well it's her driving habits!! I drove it from here to Louisville Ky to DarkSharks, picked up a Complete C3 Exhaust System in one piece!!(from the manifolds back to the Mufflers) Strapped it to the rack on top and drove home,Averaged 21-22 ROUND TRIP!!
PS Every Vehicle will be a little Different,but they all have a "Sweet Spot" where Everything Just Sounds Right,Feels Right and Will get the Best Efficiency and Least Ware and Tear on the Drive Train!!!
Women,I haven't a Clue,
I'm on my 4th one and there won't be a 5th!!!
Don't get me wrong,I boot them in the butt once in a while,But I don't beat them!!!
:cool
