DanC
I purchased this car late last year and only drove it a little while before storing it for the winter, but I noticed the heater performance was pretty poor. I never owned a car with auto temperature control and just attributed it to the control system.
Since the weather turned cool here in New England, it reminded me the heater doesn't work very well.
Symptoms are fair heat for a minute or so, then it tapers off to not much heat.
Under the hood the supply hose to the heater core is hot but the return coming out of the heater into the coolant tank is cool, indicating poor flow. There is an in line check valve in the supply that I'm suspicious of.
The engine coolant runs at about 195 degrees, so the thermostat and the rest of the cooling system appears normal.
It seems either the heater core is blocked or the check valve is not opening very much or is just stuck mostly closed.
Does anyone know the purpose of the check valve? I can't find any mention of it in the factory service manual. I'm thinking of removing it as a troubleshooting tool.
Any advice or experience with this kind of problem will be appreciated.
