94 LT1 sputtering, bad opti?
  • Thread starter Thread starter 94vette
9
94vette
I have a 94 LT1 coupe that seems to missfire at idle and sputters under acceleration. There are no codes present, and the fuel pressure is good. Could it be a bad opti? I have a k&n air filter which I cleaned and lightly oiled. I have a granatelli mass air flow which I lightly cleaned with a q-tip. There is no oil residue from the air filter in the air tube. I also have a bbk throttle body that I have cleaned out.
I have replaced the battery, alternator, spark plugs, plug wires, o2 sensors and fuel filter.
Anyone have an idea?
P.s. Also no heat with all new a/c heater controls, programmer, and heater control doors. Need the heat bad. East coast chill coming soon.
Thanks.
That's what my '94 did when the opti went bad. That's just what they do unless you are one of the lucky ones.
Jeff
Opti spark about $295.00 if you look around type in opti spark in the form and I think you will find alot of info on them.
Pace chevy has a good price ,their in Ohio.
Water pump will have to go also.
Touching the wires on any sensor is not good even with,a Q-tip
there are burn off sensors to clean those wires when they are dirty .
Just my o2:D
You wont get a code if the secondary ( cap and rotor ) is bad.
