94 tire size
  • Thread starter Thread starter sumoboy
S
sumoboy
Does anyone know if the 255 45s on the front and 275 40s on the rear instead of the 285s will make a big difference. I was given a pair of new 275 40s to use on the rear. They are only 1/4" or less in diam.
If your question is can you run 275's on the rear instead of the 285's the answer is yes you can.
In fact, they are even a stock size, if you had 9.5" rims all around.
