'95 C4 Courtesy Light Grounding
  • Thread starter Thread starter tvalley641
T
tvalley641
I'm having intermittant problems with my courtesy lights coming on as either door is opened. I've heard that it may be a poor ground in the circuit (fiberglass makes poor ground, dontchaknow!).
Anyone know where that particular circuit grounds? I'm just lazy; I repair electronics, but I just don't have the energy to find the exact source on my own. It does take driving time away.
Thanks in advance,
Ted
Lazy like me
Try removing the door pin switches first & cleaning them.
Mike
That was my first thought. Thanks
Vigman -
I appreciate all the help you've offered me since I've been here. I've been trying to return the help to others.
BTW - You may have been reading my inquiries about the intake manifold seals. I'm going to remove the plenum today and have a question. If you can't answer is, do you know who I can address it to?
It is this - I can find nothing in my Chilton's about using Loctite on the manifold bolts. I thought I read somewhere to use that because the aluminum causes a lot of movement and potential loosening of the bolts. Do you know what the experts advise on this?
Ted
I don't like to jump in but I would say no loctite. What I would do is bolt the manifold on, run the engine and re-torque the bolts. Then I'd drive the car for a couple of weeks and re-torque them again.
just my 2 cents.
Rich
RJK -
I don't mind you jumping in.
The bolts I removed had some kind of baked-on gook on them; about 5/8" up each bolt. Kinda looks like hardened Loctite, or something, to me.
Ted
No Loctite!
Permatex NON HARDENING thread seal!
Mike
