S
superhorse
my 95 has a high idle about 900 rpm... I replaced the tb to a bbc 52mm. , checked all vac. lines it did this before changing tb, when coming to a stop push in the clutch it will idle down to 1100 rpm stay there for a while before dropping to 900, still high. the car runs great otherwise, no sign of vac. leaks had it scanned it was ok ,no codes.... please help.. i'm stuck with this problem has anybody ever seen this kind of problem. any help would be great....thank you.... rob....
