B
billet 00
this is for my fathers CE. he had a bad alternator kill his old battery. we got a new alternator and he got a Optima red top battery. everything was fine, charging 14 volts. today he turned key and dash lit up like normal but when he went to crank the engine he heard a "pop". we figured it was a fuse. now, i dont know much about vettes but the only fuses i can find are the 2 small blocks under the hood and the large block on the passenger side dash. we checked all of those fuses ( visually and electronically ) they were fine. when you turn the key to the "on" position you get nothing, no power anywhere, same when you are cranking it...nothing lights up as if there were no battery. we checked the terminals from the battery, they have 12 volts. there is a "ticking" noise comming from under the dash near the fuse block that we dont know what it is. it ticks with no key in the car. we are stumped. if you need any more information please let me know. any help would be great !!
