LT4 96 LT4 HELP where is the fog light fuse?
1996 LT4 Topic
Dammit man
Lafayette LA
1996 LT4 CE
I hand the left fog light go out. I put a bulb in now both lights don't work????
I can't believe I can't find the fuse for the fog lights. I have looked in the in the owner manual and the maintenance books.
I looked thru the 95 Helm's & the only info I can find is that the fog lights work thru a relay that is operated thru the headlamp switch. Don't know if that is any help?
They are operated by the "tail" 15A fuse, IP fuse 6. You can probably infer that unless you have other external lamps (like park and turn lamps) out it aint the fuse!
There is a fog lamp relay on the right hand (passenger) side of the IP clustered with several others in a box.
Does the fog lamp LED on the switch come on?
Don'f forget! If you have the headlights on, and the high beams are on, then the fog lamps will be off.
