LT4 96 LT4 HELP where is the fog light fuse?
1996 LT4 Topic
Dammit man
Lafayette LA
1996 LT4 CE
I have looked in the books and I still can't find it.
I changed out one of the bulbs now both don't work????
Is there a fuse for the running light switch under the headlight knob, it seams to be out too.
Pull out all of the fuses and check them one at a time. It will only take 2 minutes. You might find that it is mismarked like I found my fan relay fuse was.
you pushed the button to turn on the fog lights, right? (sometimes it is the stupid stuff we overlook:D )
For the fog lights to work, the head lights or parking lights must be on. Didn't forget that?
Just trying to cover all the bases.
I have no idea which fuse covers the fog lights.
It's possible you blew the fuse when you attempted the one bulb replacement. As others had said....ck ALL the fuses first. If all looks good, I would pull the headlight switch and test w/ meter. Maybe it is defective. Good luck and keep us posted!
They are operated by the "tail" 15A fuse IP fuse 6. You can probably infer that unless you have other external lamps (like park and turn lamps) out it aint the fuse!
There is a fog lamp relay on the right hand (passenger) side of the IP clustered with several others in a box.
Does the fog lamp LED on the switch come on?
Don'f forget! If you have the headlights on, and the high beams are on, then the fog lamps will be off.
The fog light LED does not come on. I have tried it with all light combo's. The fog light bulbs look good. I am heading offshore tonight so I can't do anything for a week or so but if anyone can think of something give as a shout.
Thanks ya'll
