Rain
Sorry to post this knowing there are at least another dozen in the archives. Reading them all tell me to check the fans. Are they coming on at high temps. Test the thermostat in a pot of boiling water. See if the water pump is weeping and needs replacing.
But just to give me a bit of direction, here is what happened today.
Have had this 96 for a bit over a week. Today took it out on a house hunting trip. Maybe a bit more stop and go traffic than typical for the MS Gulf Coast. Did hit some school zones and bus stops.
Noticed the Oil Temp was up between the next two lines above 215, and the Coolant temp was up near the 2nd line above 185.
Both dropped when I would be moving. Oil eventually returned to normal. Coolant would climb sometimes to nearly the grey area at a stop light and then return to "center" when moving.
Going in for an oil change this week and a general "look over". Those of you who are not shadetree or pro mechanics, do you go to the local Chevy dealership or has your local Vette Club turned up a trustworthy indy expert to do your work???
Thanks and again I aplogize for the repeat post... Guess with warmer weather on the way, others will repeat this post....
Rain
MS Gulf Coast
Rain
MS Gulf Coast
