93Rubie
Hopefully, someone more knowledgeable than I like GMJunkie or Hib will chime in on this one.
I got a 94 I'm working on for a guy. I have NOT totally completed the FSM diagnostic steps yet. This post is so maybe one of you guys have ran into these issues before and maybe I can avoid tearing the whole dash appart to test various modules. Here goes...
The HVAC system is not working correctly. Cannot control it, lights flash for 1 minute on start up meaning I have a problem. Problem is I cannot get the HVAC Control Head to go into Diagnostic mode. Any ideas short of me tearing it out of the dash to continue FSM procedures?
I have courtesy lamps that stay on for 15 minutes regardless of door open, shut, doors lock or unlocked. Only go out if you go to ON with the Ign. Key. or if you wait 15 minutes. NO CCM DTC's, testing Door Ajar switchs and key switchs via CCM Input Check, those are OK at this time and working properly. CCM can control Courtesy Lamp Relay, switches them on and off every 3 seconds in Output Control Mode.
I also have no Tone(S) from the Tone Generator. Security Light Flashes for 30 minutes when unlocked, doors shut then goes out. It will stay on for 30 minutes if shut doors and lock them.
I should note this car has what I believe to be an aftermarket alarm system.
I did a parastic draw test with these results:
0-15min 3.40amps Courtesy Lamps ON
15-30Min .22-.39amps Security Light Flashing-Doors shut and unlocked
30-1hr 5 min-.22amps Security Light OFF
I have a major draw on that battery, needless to say.
Quite frankly, I have so many electrical issues that COULD be related as the systems are intermingled. I wonder which direction I should go in???
Also, some ding dong disconnected the E-brake cable at the brake handle. I reconnected and discovered that the right side mostly and some on the left side, the parking brake is engaged. The levers are off there stops a little.
Obviously, when they where not connected to the brake handle the levers touched the stops and parking brake was NOT engaged. SO my cables should be ok, FSM has an adjustment procedure but says that it will NOT correct my above condition. The brake handle does NOT ratchet when connect to the E-brake cable.
OH, and the Back Up Lamp Fuse Blows when you put the car in Reverse. Sweet!!! I love shorts to ground.
Also, the Water Pump is leaking, but not on the Opti-Spark. The right side of the engine where the pump meets the block is where the leak is. None on the left or middle where it is driven by the cam. Pressure test made it leak but very small leak I only dropped 1 psi in 15 min. cold. Could see the coolant very slowly dripping out.
My question on the above is, if the pump seems ok, can I just get away with replacing the water pump to engine block gasket???
I have been making progress on this slowly, I work on it in the evenings. Really just got going today, this might turn into a pain the butt. I got about half the car apart already.
