A arm bushings
SteveL
RI
1981 coupe
The poly bushings that I bought have the steel outer sleeves installed do these have to be pressed into the A arms? They also came with the special grease but I'm not shure how to grease them because they are in the sleeves already. Should I press the bushings out of the sleeves then grease them? All the posts that I have read said that the poly bushings didn't need to be pressed in. Any suggestions?
Steve
These are made by Prothane and I got them from Covette America. Has any one else used these before?
Steve
