A/C control
joe1975
Louisiana
1975 Orange L-82 4 Sp.
anyone out there with any a/c control exp. replaced horizonal switch on the side pre. owner had installed 2 toggle ewithes to control comp. and the high speed fan switch they worked With new switch doesn't work, any quick checks on this someone can help with
A/c
Joe,
I can't quite figure out your question. I have a 75 L48 w/air. I can look at mine and let you know how it's set up if you can clarify your question a little.
Bill
It appears to be an actual power problem with the switches Bill I'm looking thru a buncha spliced wires Thanks for the offer I might need all the help I can get,Thanks again.
