baxsom
ok i have 3 questions at once and didnt want to start 3 different threads.
please help me on these.
1. i thought 454s were 2 bolt mains but i took the oil pan off and each bearing cap has 4 bolts. is that a good or bad thing.
2. in the past someone has replaced the 454 heads with 427 heads. what does that mean.
3. i thought my rear main seal was leaking (thats why i pulled the pan) but the back of the engine is dry. the torque converter is dry. the rear main cap is dry. the only oil that i could find that was out of place was on the side of the engine where the inspection plate that covers the torque converter. could that have came from a leaking oil pan gasket instead.
i would have thought that the rear main was leaking that there would be oil all over the place once i pulled the inspection pan.
if anyone can answer these i would really appreciate it
thanks
thanks
