A.I.R pump supply hose
S
sothpaw
Can anyone describe to me where this
hose is located or how I can i.d. it in
an early LT1?
Reason I ask is that I am trying to install
an SLP air induction kit, which calls for me
to extend this hose with new hardware.
I have changed the air filter before and I don't
recall removing/replacing a 3/4" dia. rubber hose,
which I assume from the instructions is
what the A.I.R pump hose should look like.
Thanks in advance for any hints!
W
Wheelie
Check in front of the drivers side front wheel, thats where the A.I.R. pump is.
Trance_LT4
Suffolk, VA
Red 96 LT4 coupe
The hose they are refering to is the one that connects to the driver's side of your factory air cleaner assembly. Its a 1.5-2 inch rubber hose with a 90 degree bend in it, that attaches to the bottom piece of the plastic air box near the top of the air filter, but before the rubber hosing leading away.
