rough,
The design-type fitting will depend on the type of hose you use. At work we use teflon inserts with SS braid re-inforcement. These are for high pressure (for the most part this would mean 3,000 to even 4,000 PSI service), but we tend to use them for medium pressure to increase reliability and durability.
Flared fittings (AN Style) come in different design-types to match the type of hose. Fortunately, medium pressure applications can mostly be done by hand-assembling (hacksaw to cut the hose lenght, flaring of the braid to fit the ferule correctly, assembling, and testing). We designed a tool to ensure a straight and perpendicular cut with respect to the hose lenght using a hacksaw. This is critical, but depending on the application (fuel delivery and/or pressure levels) it is not terribly so -specially when it comes to automobiles. Most automobile applications (except for maybe NHRA) fall in the low pressure hose applicatiions.
Just a few pointers though, lenght of the hose is critical if it is a rubber hose. It may look nicer to make a particular section 18" long (for example), but rubber hoses tend to shorten when under pressure more than SS braid-reinforced teflon inserts. Pressure test the hose to twice the service pressure to ensure reliability. You can always substitute with higher pressure-rated hoses for lower pressure applications but obviously not the opposite.
Some types of hoses require machine or tool assembling (such as swage-type fittings) but generaly speaking not the reusable style of fittings (swage-type are one-time-use fittings).
