tchort
Hi fellas, I am in need of your expertise once again. Basically, the ABS system is no longer going through it's self-test at 4 mph as it should. It still works if I hit the brakes hard, and there are no warning lights on the dash.
A bit of background: I had some bodywork done recently. The driver's side floorpan was busted. In the process, the moron cut 3 of the 4 brake lines that are routed on the driver's side, going to the ABS unit. Well, sh*t happens; they fixed the lines and bled the brakes. There are no leaks.
Now, as I mentioned, the ABS no longer goes through its self-test. Also, the brakes feel mushy. Like, there's more pedal travel before they bite.
Any thoughts?
Any thoughts?
