woodpuppy
I have the dreaded C1214 H C error code on the TCS in the DIC.
I think I have read all previous post regarding this code and believe I have tried all remedies EXCEPT to replace the failed unit.
I have 2 questions; 1. How do you remove the electrical connection at the front of the unit? It has a gray handle that you can pull up that appears to release the connection, but I can't seem to get it completely free and move it out of the way.
2. Is there a way to make the dash lights go off while the system has an error or while it is being replaced.
Pulling the 40A fuse doesn't make them go away. I don't mind driving without the systems working properly, but I can't stand to see lights on the dash.
This is on a 2001 coupe with ABS, TCS, and Adjustable Ride (FX51 or 52 I think).
Thanks,
Jeff
Thanks,
Jeff
