ABS light coming on
pdeason
Alabama
1991 White Coupe
My son's 91 model will flash the ABS light after you have been driving for about 10 minutes. It stays on for a few seconds and then goes off just like it would at startup. After that it does not come on again. Any ideas?
Take the car to a parking lot or a back road and get up to 40 mph or more and then just stomp on the brakes and make them go into abs mode. If you have a piece of dirt in the sensor this may shake it out. At the very least it will tell you if the abs is actually working.
I just looked at my fsm. In there it mentions that the brake fluid level switch will give signals if the fluid is low you might look at the fluid level.
