ABS module replacement
FLIR_man
Winter Park, Fl USA
2000 coupe Metallic Blue
Does anyone know if the ABS pump (it's a 2000 corvette) can be used with either the M or V electronic module? My electronics are ok but the pump has bad threads on one of the output ports. The existing unit is a V.
I see no reason for the pump to be different. My parts info does not show the part numbers for the pump. A dealer might maybe. Just makes no sense that they would be different.
Mr. Sam
I found out there is a difference, the modulator valve (pump) comes with and without active brake control. Just a fyi the part number of the modulator with the active brake control is 10417038 which is the V version.
Yes, I had the part numbers for each but I still think the motors would be the same.
Not sure why the modulator would be different between the versions but it is. I know why the electronics would be.
