abs motor area wet???
dreamcometrue4me
Illinois
1991 coupe
I am getting water in the ABS motor area behind the drivers seat. From what I can tell it is not coming from above. I have the storage tray in there with papers in it and they do not get wet. Has anyone else had this problem? Where could it be coming from? Is it because I have an aftermarket piece on the back instead of the window? ABS motor is curently not working but I think its because it got wet so have to wait and see if it dries out and works again.
If You check the passenger side under the foam insert for the jack, you'll probably find water in there as well: which is the main reason the radio receiver goes bad. Water getting around the rear window seal is a common problem with C4's. In your case; where the rear window seal would normally be. The tray isn't wet because water is coming in behind and under the carpet and backing then seeping into the wells.
