Hi there,
Well, your 1243 for the TCS shows that the control module sees that your ABS pump has stalled, or is not fuctioning correctly.
This is tough, as it is located at the rear of the vehicle, attached to your rear subframe, behind the differential.
As for your PCM codes, the 463 shows an issue with the left side tank sensing unit, that has higher voltage than is supposed to be seeing. The 1626 is for the fuel enable signal from the BCM was not received. You may have experienced a no start at one time or another. The 1571, as long as it is H, is a normal condition on the 97 year, and can be ignored.
Radio and IPC are communications codes, and can be disregarded, unless they become C, for current.
The HVAC, shows a short within the left hand actuator. You may be able to rehome the system, by disconnecting the negative battery terminal for 5 mins, and see if the code resets.
I would go for professional diagnosis on the PCM, and the TCS problems.
Hope this helps, c4c5
