abs
  • Thread starter Thread starter tunedportvette
T
tunedportvette
Hey everybody I am looking at a 2000 vette the owner says the service abs light is on any ideas? Could this be a costly repair? Thanks for any help
That's a difficult thing to diagnose without knowing what CODES the car may be sending. Is it a communications issue- certain signals are not being received- or is an actual mechanical issue?
In either case, if it were me, I'd want to have someone who is experienced in servicing Corvettes diagnose it fully, and provide me with a reliable cost estimate for repair, before I seriously considered buying the car.
Yes,it could, Lay some codes on us and let's take a look see! :thumb
:D
Turn the key to the ON position, but don't start the engine. Clear any present messages by pressing the RESET button. Hold the OPTIONS button down, and press the FUEL button 4 times. This will get you into the CODES section of the DIC. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. Any code that ends in H is a history code (something that has occured in the past) but is fine now. Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# CODES".
