Sorry I did not respond sooner. There's only three items that receive power when you're in the a/c mode: the a/c clutch, the pressure cycling switch and the idle solenoid. I doubt the pressure cycling switch is the problem with the fuse blowing, but it could be the cause of your compressor not cycling off. The only way to tell is to use an a/c gauge to see if the low side pressure pulls down to 28 psi. At that point the switch should open and turn the compressor off until the pressure reaches 47 psi, at which the switch will close and turn the compressor on. This is what is called cycling. If the pressure pulls down below 28 and does not shut off, then the switch may be stuck. If the pressure does not pull down, you're probably short of freon. Now back to the fuse: Check the resistance of the idle solenoid which should be 23 ohms. The clutch should be 3.6 ohms at room temperature. If either one is lower than spec that's what's blowing the fuse. If both measure OK. then check for a shorted green wire that's going to the solenoid, pressure switch or a/c clutch. The diode is rated for about 400 volts.
