gm79vette
New member
Hi! Does anyone have a procedure for replacing the AC evaporator when the
engine is still in the car? Thanks!
If it hasn't already been replaced recently, I would replace the heater core while you are in there. You should be able to pull the evaporator without having to remove the headers but you might find it easier if you remove the coolant overflow tank.
On a bright note, you are working with a small block. I replaced the evaporator and heater core on my big block and I was unable to speak by the time I finished it.
Once the headers have been removed and everything between the dash and firewall on the passenger side it's fairly easy.
You may find, as I did, that the housing has cracks and holes that weren't factory installed. A little fiberglass work, a coat or two of primer and you can test fit the housing. Probably best to do it once without the evaporator core so you know what it feels like when it goes back together.
My rocker arm covers weren't really in the way but once I sprayed the semigloss black I didn't want to scratch it up.
Compared to replacing the evaporator on my PT Cruiser, this was a pretty easy job.
Tim, you're right -- I would gladly do without A/C if I didn't live in a sauna 300 days a year. Even up your way it's been warm lately. Our afternoon highs are in the low 90s but mornings starts at 80.That picture makes me just SOOOO happy I don't have A/C
Hi, I am thinking of changing the evaporator in my 77 right hand drive it has the steering going through the box is this a big job with the steering the way it is. any suggestions Alan from down under Aus.
