B
BoeingMan
New member and would like to say hello to everyone
...Hi All :0)
I was wondering if anyone has tried to install a pre oiler of the type Accusump sells (or any type pre oiler) on a C5.
I would like to install one but wanted to get some advise from anyone who has some. Accusump sent me the parts list that I needed. All parts would cost about 450 dollars total.
They suggested to tap into the oil system either through an existing oil plug on the engine block (does anyone know where one exists, accusump says there should be a few access holes pluged with screw type plugs)or to use their oil filter adapter kit wich would tap into the oil system via the oil filter mount.
Don't really want to use the oil filter adapter kit. It's suppose to fit in between the block and filter thereby lowering the filter about 1 and 1/2 inch. Being that the underside of the C5 is basically flat, I don't really want the oil filter sticking out 1 1/2 inches...
Any coments/suggestions??
:eyerole
...Hi All :0)
:eyerole
