C
CPOTomG
Using the "Accessory" 12 V plug found on the passenger side under the dash I installed a CD radio. Several times my car wouldn't start and upon removal of the key from the Ignition switch the steering column wouldn't lock.
My dealer says the CB radio was draining some capacitors and causing the car not to start.
Why would GM provide the Accessory 12 V plug if it would cause this problem?
