I've heard this advice, as well. Also, I have heard about not overfilling the oil pan, etc., yet over the years lots of service people have told me that going about a qt. over doesn't hurt at all notwithstanding all the doomsday scenarios, and, in fact, helps reduce oil temperature. Also, in many cases (as in my '81), you will see the owners' manual recommend putting in 5 qts. when you change the oil filter. However, even if you use the long filter, you will still end up with about 2/3rds of a qt. above the fill line. Perhaps it's all different with the ZO6, but this seems to be very contradictory. Someone should ask GM to design a proper oil pan with baffles. trap doors etc. to begin with so this isn't even an issue at all.
--Chris Kennedy
Houston, Texas
