Adhesive for plenum pipes
  • Thread starter Thread starter insiswe
I
insiswe
Can anybody advise me on the Loctite product used to glue
air and water pipes into the plenum as mine have come loose.
The clearance hole is 0.7mm.Does anyone have a method for doing this as the adhesive is difficult to keep in place.
For my antifreeze lines going to the plenum I have little hose clamps that secure mine and I don't have any leaks. For the vacuum lines, I went to the auto store and bought very small zip ties and secured each one down with those and have had no problems. I think the Loctite is only used on bolts.
Jay
I believe he means for the fittings themselves Jay.
For those I believe Loctite 620 is the prescribed fix. But if you can not get that I'm sure J-B Weld would do the trick. And there is actually a faster J-B Weld called J-B Quick. It sets in about 5 minutes.
Just smear a little around the end of the fitting going into the plenum then press them in. Keep a small towel handy to clean up the edges around the fitting.
