On the Quad, looking at it from the front of the car...
The idle adj. is on the RIGHT hand side, if you look where the linkage for the gas pedal comes to the carb, then in front of it is a screw adjustment, you can either us a flat screw driver or a 1/8" socket will work too.. it adj the stopping travel of the linkage to allow either lower or higher idle RPM.
This adjustment ONLY effects the idle, it doesn't effect fuel or air mixture
