J
Juskie77
Does anyone know any tricks for adjusting the door glass in the weatherstripping? The window motor seems clunky and inconsistent on where the glass stops and how the glass fits up against the weatherstripping. I read through the FSM and it says to sit in the car close the door, keep all the slides loose, let window up and use a suction cup to set the glass where you want it and tighten everything down. When I do I can't get an even seal at the top and it seems to change each time I put the window up and down.
FYI, 77 vette with power motors, new weatherstripping, and window motor.
