C
c4ever
I just opened up my driver side door panel on the 85 and pretty much got stuck (even with the manual) on getting the inside cover plate off. Does anyone know the easiest way to release the rods for the handle and lock mechanism? I can't believe the way they designed this thing
I can reach behind it and feel the ribbon cable has broke. I was wondering if I can somehow replace it without taking out the entire assembly? There is an allen key bolt that is at the top of the ribbon cable but it seems the nut behind it is turning free and there is no way to get to it. Any advice is appreciated. I don't want to hack at this thing and the manual isn't really descriptive enough. This is the first time it's ever been opened up and I'd like to see it go back together correctly.
Carlo
I can reach behind it and feel the ribbon cable has broke. I was wondering if I can somehow replace it without taking out the entire assembly? There is an allen key bolt that is at the top of the ribbon cable but it seems the nut behind it is turning free and there is no way to get to it. Any advice is appreciated. I don't want to hack at this thing and the manual isn't really descriptive enough. This is the first time it's ever been opened up and I'd like to see it go back together correctly.Carlo
You just can't beat the satisfaction of knowing it was done right and thanks to this forum I'm not afraid of jumping in.
