The73vetteman
Just found some severe scoring on one of my front rotors. It's probably 1/32" deep so I'm thinking that I'll need to get the rotors machined, or maybe replaced. Can anyone answer these questions:
1. What's the minimum rotor thickness before they need to be replaced?
2. the rotors are still riveted to the hub. I'm thinking this means they're the original rotors, which means they've done 116,000 miles. I see Zip and others sell rotors without the hubs, so am I right to assume that I can just drill out the rivets the same way people do on the rear rotors?
3. If I drill out the rivets should I put new ones back in? (I'm not that worried about originality, only safety.)
4. Any other points I need to consider before I start work?
'73
'73
