hdb
New member
airaid "econoaid (#1005) = check engine light
Last night I installed an airaid "econoaid" throttle body spacer on my 2003 C5. Started the car, it idled a little rough at first, then the CHECK ENGINE LIGHT came on. Went for a little drive, and seems to idle fine and run good, but the light is still on. Is it true disconnecting the battery for a few minutes will make the light go off? Thanks in advance for the tips!
