korvettekarl said:
I have installed several (5) Edlebrock systems. I like them for the completeness of the system. They are dependable and easy to install.
KorvetteKarl & Everyone else,
How about tuneability? Do you have any burps or farts in the system?
What sort of air cleaner housing did you use?
I do like the Stealth Ram system, but I am not really that keen on changing the bonnet. The reason is that I want the old 81 to look as stock on the outside as possible. By stock I mean that I have even changed the American Racing wheels back to stock steel Rallye Rims with 255/60/15 BF's just as the build sheet says.
I like the classic look of this 'no frills' Vette without code N90 Aluminium wheels.
However, that said, the engine bay and driveline can be modified, so I am looking at a serpentine belt system from March (Ultra Drive) and a set of thermo fans first up followed by injection at a later date.
I have just spent some $$$ on the matching numbers L81, bored out 20 thou, original crank, decked block, Larry Perkins race kit (pistons), shaved heads, 1.6 Yella Terra Roller Rockers & slightly lumpier cam (just over stock). That is about as far as I would go on the matching numbers block, any more and I would be better off buying a crate engine, besides the 2 bolt mains limit things.
Getting back to the mods. The March Ultra Drive serpentine belt system really appeals to me. I saw something simular on a 502 69 big block Vette here in Oz, and it looked really good. It wasn't all 'blinged up' with chrome, it looked practical and made good use of an already tight engine bay. This is on the shopping list and is in another post.
The FI, a long term shopping list item, but something I would consider. My Edlelbrock 1903 (795 CFM) carb has a major flat spot when you dump it, so I'll have to rip her down to me carby fella to have another look at.
I am not bagging the Q Jet, I reckon it is a far better carb than the holley that the previous owner had on there and it gives the old 81 a wake up call!
The next step is FI.
The question then is air intake. No use sucking hot air from inside the engine bay. I am interested in clean cooler air from in front of the radiator.
I'll check out any links you guys have, if you have any more info, please let me know or post.
PS Check out our Club website, I am not sure if the 502 was on there or not.
www.corvetteclub.com.au
Cheers
Tony
