Aftermarket Opti-Spark?
vee93
Mississippi
1993 Medium Quasar Blue Metallic Coupe
Anybody have any thoughts regarding DynoTech
Engineering's "DynaSpark High Performance GM Opti-Spark Distributor Replacement"?
DTE QUOTE: "This performance distributor is CNC machined of billet aluminum and is hard anodized for an attractive external appearance, while providing a durable finish that will resist corrosion from the element."
Cost about $599.00!
Good God! When does it end? I just had my A/C fixed-$1100+ for new compressor and all the accoutrements.
Sounds expensive as you can get a opti for about $400.00. It doesnt seem there is a low cost replacement for the opti. This might claim to be rebuildable but who knows what that cost.
Two weeks ago Richmond 3.54 rear axle, one week ago MSD Blaster Coil & adjustable fuel pressure regulator, yesterday Headman long tube headers (burned one spark plug cable this morning so I need a new set), next week MSD 6A ignition module & Mr Gasket pulleys set...
As you can see my guess is it never ends!!! :v
Hoops! I almost forget that I need a o2 sensor.
