WOW... 10 cfm at 90 psi... For that requirement any compressor that you are looking at will not be portable. Movable yes.... portable NO....
I am a big fan of Coleman... I have found that when they get into a market, they tend to be higher quality. My requirements were: 110 V, Portable, over 5.5 cfm at 90 psi, maintenance free. I bought one like this: This will run most everything I own.
[font=arial,helvetica]
MODEL NO.[/font][font=arial,helvetica]
CL0602712[/font]
Max Pressure 95-125 psi [/font]
CFM @ 40 PSI = [/font][font=arial,helvetica]
7.7 [/font]
CFM @ 90 [/font][font=arial,helvetica]
PSI = 6.0[/font]
MOTOR [/font][font=arial,helvetica]
6 Peak HP [/font]
VOLTAGE/AMPS [/font][font=arial,helvetica]
120 / 230 [/font]
AIR TANK [/font][font=arial,helvetica]
27 Gallons [/font]
PUMP [/font][font=arial,helvetica]
Oilfree, Drirect Drive [/font]
WEIGHT[/font][font=arial,helvetica]
160 lbs. [/font]
LIMITED WARRANTY[/font][font=arial,helvetica]
2 year[/font]
In hindsight.... the beltless and oilfree version IS VERY NOISY! I THINK I WOULD CONSIDER ONE WITH A BELT AND OIL NEXT TIME. I bought the maintenance free one because I work on a project like mad for a couple weeks..... then never use it for a couple months.
I looked at Coleman's site and found:
CL7006016 [/font]
MAX PRESSURE[/font][font=arial,helvetica]
100 - 130 PSI [/font]
12.3 [/font]
CFM @ 90 PSI = [/font][font=arial,helvetica]
10.3 [/font]
7 Peak HP [/font]
208 / 230 [/font]
60 Gallons [/font]
Oil Lubricated, Belt Drive [/font]
WEIGHT [/font][font=arial,helvetica]
217 lbs. [/font]
LIMITED WARRANTY [/font][font=arial,helvetica]
2 year [/font]
Very nice
Hope this helps,
