OK, I'm about to purchase an air compressor and all I've read recently tells me that a Campbell-Hausfeld/Husky is plenty good. The specs are 220V, 60 Gal, single stage, oil-lubed, 10.2 SCFM @ 90 PSI with a maximum of 125 PSI and 7.0 peak HP, 100% duty cycle capable. The cost is about $350 with a nice Home Depot coupon.
I have a 66 vert shell that needs lots of TLC so this compressor will be used for all air tools including sanders, grinders and a paint gun. I searched through the archives to see what I could find in the way of info and pictures but most images were gone. What I need to see is layout and accessories required to use the compressor to work on the fiberglass body and shoot primer/paint the car. So here are the two areas I need help in:
1- Provided my choice of compressor is correct, I will need to add a 220V oultet to the garage or make a 25' long extension cord to plug it into my dryer outlet. Which is best? The house is 4 years old and already has 220v 10 amp breakers. Do I need to beef the dryer one up to 30A? Alternatively, I could position the unit closer to the dryer outlet (about 8 feet) and run copper lines to where the tools will be used. That's why I would like to see photos of layouts.
2- This compressor will deliver 10.2 SCFM at 90psi and 11.8 SCFM at 40psi. The HVLP gun I had in mind, the DeVilbiss Finishline (2 or 3), runs 11.4 cfm at 23 psi. Is that a good match? If not, any other suggestions on paintguns under $200?
What else do I need to take into consideration when running an air compressor in my 3-car garage? Pictures are worth a thousand words, BTW. Thanks in advance.
