S
Saltydog
I have a 82 vette.
I replaced the AC compressor, drier, orifice tube, and had a local Firestone shop to charge my system with 134a. I have determined that my air box doors are all functioning properly including the max air outside door. I have placed a cutoff valve on my heater core hose and shutoff water flow to it.
The AC when placed in Max cool with car running at 55 mph on highway will blow at vent a temperature of 48 degrees, which is ok with me, but when I stop a idle the temperature will increase to 60 degrees. My 88 silverado pickup with 134a gas will put out 40 degrees at vent temp when it is idling.
I am now wondering if placing some sort of relay switch to turn on the electrical radiator fan will help with my problem. It seems as though I need more airflow across the coil as happens when I am traveling at 55 mph.
If some one knows the proceedure for electrically hooking up such a relayed switch please advise me. 10 to 15 degree vent air temps are to much.
Thanks for any help.
Saltydog
Saltydog
