S
Saltydog
I have a 1982. Trying to restore it. Owner before me. cut many wires and rewired as they saw needed. I would like to some what straighten out some problems that are the result of this. Which I though I have via using the GM Shop Manual Diagrams.
My first question is:
Does the fan motor suppose to run on low all the time?
Mine does when all switches are in the off position.
I have taken all switches apart cleaned them and reassembled yet fan still runs in low speed when ever car ignition is turned on.
Note that when I place the selector switch in Max AC or Normal AC the fan switch will then work in all correct speed selections.
Also when I move the AC selector switch to vent or Heat or defrost the fan will only work in the same low speed as the off position.
I just don't get it .
Please anyone with suggestions? I would greatly appreciate them.
Thanks Saltydog.
Thanks Saltydog.
