ALDL connection
Dougs91
Olalla Wash.
1991 blue coupe
I'm embarrassed to ask but, Had to remove the drivers side hush panel to get to a bad relay. Made a "mental' note of how the connector fits into the hush panel and now CANNOT GET IT TO FIT!!!! Anyone have a closeup photo of this or a good description of how this goes back in?? It was so easy to take out.........:confused Thanks,Doug
Doug, I sure would like to help but I do not know what a hush panel is or an ALDL connector. Can you give me a hint??
Florida Guy, The hush panel,maybe should have called it what it is, the drivers knee bolster. The ALDL is the access port for reading codes. Needed to get the bolster completely out of the car,so had to remove that connector from the panel. Hope this makes more sense:W Doug
Doug, on my 90, the connector has a threaded bolt hole, center top of the connector frame. I think it's a 7mm threaded bolt that goes from inside the panel to this bolt hole.
gw962- thanks I'll check mine this weekend. I should have learned with this car to always take photos no matter what!!:L Doug
