lone73
I don't know where I got this link
http://www.babcox.com/editorial/bf/bf40419.htm but I was re-reading it just now and decided I'd post it with a question about DIY alignments. I've had major headaches getting a decent alignment from local shops so I'm constantly on the lookout for a way to get this done in my garage with minimal labor and expense.
I've been considering several different types of machines but it appears to me that most of the $200 to $300 garage alignment tools don't do toe adjustments. With that in mind I was thinking of a way to do an easier alignment than using the string method - too time consuming to set up. I had the bright idea of using a laser pointer connected to some home made fixture that would shine forward to a wall or other suitable surface. The point on the wall could be marked and the laser light tracked to measure toe changes more effectively and probably WAY more accurately than using strings on the side of the car. A string would still have to be used to establish the centerline of the car running underneath or somewhere but that wouldn't be as bad as having to set up three strings.
Anybody got any thoughts on this or seen a system that acomplishes the same thing?
