Peer81
Well, it was a nice and distructive eventing yesterday...
Got the carb back together after some changes and on the engine. Battery full and starting, hat to crank some time to fill the fuel bowl but then she fired up. In an attemped to get a steady idle rpm I played a little with the gaspedal. Then I noticed a little smoke comming from the vent selector, looking a the volt meter it was in the red area in the right corner!
hnoes At the same time some smoke was coming from under the dash at the passender side and more smoke from the center console. So I shut down the engine as fast as I could, and disconnected the battery (lucky for me the battery terminal was not tight so I could get it off in a split second.
My first thought was nice burned alternator regulator so I didn't give it some thought first check the carb and everything. I walked to the engine to see I had a leaking throttle body gasket in the left front, fuel was dripping on my intake manifold... Lucky for me the engine was still very cold with only a few second of running time. Easy fix to change it with another gasket. Put the carb back on the engine and begun to inspect the damage the 18v system made.
All center gauges and lights aren't working anymore, headlight and cornering indicators do work. Engine wil not start, rear window defogger didn't work, cornering lights don't work and that is about it. We begon checking the fuses, all seems to be in place so no problem there. Only problem is my aftermarked alarm burned a 7.5A fuse and putting back in a new one it burns right again... Checking if there is 12v at the gauges fuse shows there is no 12v there. Then checked if the fuseable links near the starter are still in place. There is 12v coming from the links to the ignition switch. Looking in the shop manual in the wiring diagrams I could chase the problem back to one thing, it looks like IGN1 from the ignition switch doesn't work anymore.
So this evening it's head first under the dash again to get the ignition switch from the steering column. Yes you have a hobby or you don't...
Greetings Peter
Greetings Peter
