ironmoo
Has anyone converted a 3:00 to a 9:00 position for your alternator? If so, please let me know how it turned out.
I'm having trouble finding a new alternator (mine is a 9:00,) in my '82. Finding a 9:00 that is rebuilt is no problem but I wanted a new one and all the shops I've called or visited are unable to locate it. At Napa auto, it indicated 9:00 on the stock number and still when I opened up the box, to the dismay of both me and the helpful employee...3:00 position! We ordered a couple from the warehouse and same story.
So I called Ecklers and was checking out the chrome 85 amp and sure enough, they only have a 3:00 position. The tech suggested to loosen the 4 bolts on the back housing and carefully spin the back 180 degrees and snap back into place. The problem I found is the top and bottom brackets on the casing bumps into the 4 bolt housing causing me to pull farther back on the back case to create clearance to spin the 180.
I tested this with the old alternator and it seems to work, however in doing this I pulled too far and the shaft came out okay but the springs/contacts popped out. Are there any suggestions on how to keep the springs and contacts in place while replacing the shaft?
So options are:
1) get the chrome alternator and spin it myself hoping the shaft does not come out too far when clearing the housing. (Thus causing the springs and 2 contacts pop out.)
2) go with a 1 one wire Alternator (which I've researched on this forum, but still wonder what problems that may lead to in a '82)
3) replace with a rebuilt 9:00 alternator and grumble over it.
Any thoughts or advice will be appreciated!
-Moo!
So options are:
-Moo!
