7
72LT1Steve
I just recently ordered and received the rebuild kits for my original #'s matching alternator. I had been thinking about going through it since last year & finally got off my rear end and obtained the parts to do so. The alternator has/had some 81,000 miles on it.
I'm glad I did do something finally, because when I tore the alternator apart I found the the bearings basically worn out and very dry. The front bearing had it's casing crumbling (basically a sealed bearing) & no grease there what-so-ever. The rear had minimal grease & was showing it's age.
Assuming you have your original alternator & plan on keeping it & not just replacing it when dead, have you given any thought to at least grease the bearings inside at a minimum?? I'm glad I tore into mine and rebuilt it for two reasons:
1). I'm sure the alternator would have failed in the very near future. &
2). It gave me the opportunity to thoroughly clean the case and other parts of built up decades of grime. It now looks factory fresh and clean
Just something to think about
Steve
Steve
