toobroketoretire
Banned
After paying $40 to get my TH700R4's broken aluminum tail housing TIG welded (and getting a lousy job) I decided to do further experimentation with the aluminum brazing rod I bought last year from Harbor Freight for $15. I experimented on a few pieces of scrap aluminum and quickly found out what you should NOT do; pointing the torch flame (propane, MAPP, or acetylene) at the rod itself.
Here's step-by-step instructions of what you need to do to braze aluminum:
1. Either sand the aluminum to bright and shiny or glass bead/sandblast it to remove all oxidation
2. "V" the crack just like you would for any crack repair
3. Heat the cracked area to 725-750 degrees, point the torch away, then apply the brazing rod into the 725-750 degree "V" and it'll flow into the V just like any lead/tin solder would flow
4. Allow the repair to completely air cool all by itself because water will make the repair very brittle
By the way, the repaired joint will be a LOT stronger than the parent metal.
To watch aluminum being brazed Google "Brazing Aluminum" and there are dozens of You Tube videos on the subject.
