toobroketoretire
Banned
My new TRICO windshield washer pump arrived this morning and when I went to install it I ran into trouble. I was running a Chinese reproduction pump and the new TRICO pump was VERY different. Note these differences:
1. The threaded inlet of the Chinese pump was 90 degrees mis-positioned
2. The outlet of the Chinese pump was also 90 degrees mis-positioned
3. The two electrical spade terminals of the Chinese pump were oriented in a different way and also 90 degrees mis-positioned.
4. The Chinese pump had an opposite rotation of the TRICO pump so I had to install the HOT and GROUND wires backwards.
Both times I ordered a "1982 Corvette Windshield Washer Pump" and although they are similar in appearance they are also very different. The OEM pumps used a plugin for the electrical terminals but that plugin would have never been correct for the Chinese pump which required separate wires and terminals. In every instance where I installed a Chinese reproduction I had to heavily modify it to be able to use it.
I bought a AC Delco "rebuilt" power brake booster two years ago and found it was a NEW Chinese reproduction that came unpainted and sloppy wet with oil all over it. Everything about it was wrong and it took me 10 hours of my time to make it usable. As I am very skilled at modification and fabrication I was able to do what was required to make it work but Joe Average would have had to send it back for a refund.
