- Joined
- Mar 6, 2005
- Messages
- 1,074
- Location
- Trois Rivieres, Quebec, Canada
- Corvette
- 63 Resto Coupe-Red 65 Roadster
Has anybody ever had the needle on his amp meter point 180' off. I just got back from the alignment shop, and while he was loosening the front bolt on the LH a-arm shaft, his wrench struck the terminal on the horn relay causing a spark.
I immediately used the quick dis-connect battery terminal so that it would not repeat itself, and once the work was completed I drove home. On the way, I noticed that the amp needle was no longer moving, and that it was pointing towards the bottom of the gauge, and no longer seems to move, one way or the other.
I remember having read in one of the NCRS mags, many years ago, that there was an easy was to reverse this situation, but for the life of me I don't remember where I read it.
Anybody ever had this happen, and know of an easy way to get this back to it's correct position, other then having to go through the removal , and replacement procedure.
;help
;help
